HEX BUG ?
JP86SS
HEX BUG ?
Post by JP86SS »
When setting a 16 bit constant and using "hex digits" as the type.
If I open the item to edit there are only 3 digits.
Should be 4 so I can set an address I want to load from for the ALDL word output.
Right now I've broken them into LSB, MSB and edit that way using 8 bit.
Works ok that way just not as 16 bit.
Set the significant digits to 4. Otherwise it will cut off the leading 0. However, that leading 0 is insignificant, so it doesn't matter.
