Please help me understand M60 V8 404 DME ignition timing
Posted: Thu Dec 03, 2015 3:16 pm
by Mykk
Hello guys,
I'm currently tuning my '95 540i/6, it has a swapped 404 DME (from 484) using a Moates Ostrich 2.0 chip emulator. Using the .xdf and .bin for the 404 from the tunerpro library the car runs.
I understand how to tune the fueling for desired effect (wideband O2 sensor & gauge mounted in the car) what I don't understand is the ignition maps. These figures can't be BTDC crank degrees;
Can someone please help me figure out what I'm looking at and perhaps translate it to actual crankshaft degree btdc ignition timing? Thanks in advance, no pun intended -Mykk
Posted: Sat Dec 05, 2015 11:02 am
by biela
Factor: 0.75 and offset:-45?
Posted: Sun Dec 06, 2015 11:34 pm
by Guybrush
Just multiplie the raw numbers with 0.352 and you will convert them in degrees BTDC.
Posted: Mon Dec 07, 2015 10:07 am
by Mykk
GuyBrush, Thank you!
Posted: Mon Dec 07, 2015 10:26 am
by Guybrush
Posted: Wed Dec 09, 2015 11:20 am
by Mykk
Here is the timing map for my application in crank degrees from a different tuning product called a Miller W.A.R chip. It's a flashable chip that replaces the EPROM and uses the manufacturers proprietary software to modify and load the tunes on the chip.
This is the 92 octane timing map in crank degrees from Miller:
This is my TunerPro .bin from the original post after multiplying by .352:
After looking at the raw ignition timing table I decided to see what happens if I just subtracted 70 degrees from the original data:
The .352 map doesn't look like what an original timing curve what come with from the factory. However the -70 timing curve is pretty close.
Posted: Wed Dec 09, 2015 1:10 pm
by Mykk
I'm beginning to think it's an xdf issue. I'm researching now how to make my own xdf's
Posted: Wed Dec 09, 2015 9:56 pm
by Guybrush
Are the maps have the same memory address?(miller software and tuner pro xdf)
Posted: Wed Dec 09, 2015 11:57 pm
by biela
Try with:
Major Order: Row
12 Rows and 10 columns
Conversion: x*0.75-45
Posted: Thu Dec 10, 2015 11:39 am
by Mykk
x.75 -45 can be a realistic timing curve for an M60B40:
I do still need to make my own xdf/xds for a different bin, learning how to via as many resources as possible right now.
Posted: Thu Dec 10, 2015 11:41 am
by Mykk
Guybrush wrote:Are the maps have the same memory address?(miller software and tuner pro xdf)
I'm afraid I don't know. Still falling down the rabbit hole, err...learning as much as I can about tuning bins and the code/software involved
Posted: Fri Dec 11, 2015 12:16 am
by Guybrush
Send me the ori file bin and i see what i can do
