Guys,
I am having trouble getting the table multiply to work right, I'm sure it's something I'm doing wrong...
Basically I have a 2 cyl engine, Cyl #1 is the base fuel map and Cyl #2 has a multiplier to correct fuelling for it. Tables for both the base fuel values and corrector are 16x16.
For example for a given speed/load point (this ecu is alpha-N) the base fuel pulse width is say 15mS and the corrector is 1.20 yielding a Cyl 2 pulse width of 18mS.
I have .xdf tables set up for both the corrector and the base fuel table. I would like to:
1. Be able to view the corrected fuel map-- this would be base fuel table x corrector table.
2. Be able to adjust the corrector in terms of ultimate fuel pulse width. I sould say that I would like to use the drag or table entry methods within the map described in #1 and have TP adjust the corrector map values w/o adjusting the base fuel map values.
Is my question clear, and is this possible?
Thanks!!
XDF Table Items Multiplication
