If the car does not go in to the WOT map, what should I look at then?
Its a 325 NV 92 402 motronic 3.1
Best regards
Not going in the wot map
Re: Not going in the wot map
Dont care that its old post.maxout wrote:If the car does not go in to the WOT map, what should I look at then?
Best regards
I think the problem could be with your TPS sensor. It could not be plugged in or just faulty. If TPS sensor signal reaches to ~3V, the maps are going to WOT maps.
Good luck.
