flash&burn plugin
andycr55
flash&burn plugin
Post by andycr55 »
Hello All
if i burn the eprom with flash&burn software starts the fine.
Use tuner pro and burn via the plugin using the same file wont even
energise the fuel pump to this so maybe a setting problem.
help appreceited.
The standalone Flash & Burn software is a bit older than the one embedded in TunerPro, but they're from the very same codebase, so I wouldn't expect them to function any differently given the same input.
