Hello if anyone is willing to help; my issue is this:
When using the newest version of tunerpro rt to edit my obd1 on my Chevy Caprice bin it does not seem to save many of my changes and the values i try and change seem to be off (line pressure and fuel cutoff speed reading as zero) to begin with. I have included my change log if anyone is willing to give some input as to what my issue may be, i would greatly appreciate it. I have tried with several bins and they all have the same issue. I have tried on two different pcs one running windows 8.1.1 black x64 and the other running standard 8.1 x64. I am running as admin and the files are not set to read only. I will copy and paste my log below.
Thank you,
MILDEW
Edit Log for caprice new.bin created by TunerPro.
01/01/2015 23:46:01 Scalar: EGR - Temperature Level for EGR Enable (KEGRTEM1) changed from -40.00 øC (0x00) to 151.00 øC (0xFF).
01/02/2015 09:13:35 Scalar: Fuel Cutoff, 1st Gear changed from 5886.47 RPM (0x01F5) to 6495.86 RPM (0x01C6).
01/02/2015 09:13:56 Scalar: Fuel Cutoff, 2nd - 6th Gear changed from 5805.35 RPM (0x01FC) to 6495.86 RPM (0x01C6).
01/02/2015 09:16:53 Flag: VATS Select (X = Enabled) changed from Not Set to Set..
01/02/2015 09:25:48 Scalar: Min. Coolant Temp. To Enable Air Pump changed from -40.00 Deg C (0x00) to -40.00 Deg C (0xFF).
01/02/2015 11:29:35 Scalar: EGR Enable, Min RPM changed from 0.00 RPM (0x00) to 0.00 RPM (0xFF).
01/02/2015 11:30:03 Scalar: EGR Enable, Max RPM changed from 0.00 RPM (0x00) to 0.00 RPM (0x00).
01/02/2015 11:34:33 Scalar: EGR Enable, Min. MAP changed from 10.40 Kpa (0x00) to 10.40 Kpa (0xFF).
01/02/2015 11:42:11 Flag: VATS Select (X = Enabled) changed from Not Set to Not Set..
01/02/2015 11:42:59 Flag: EGR Diagnostic, Error 32 changed from Not Set to Not Set..
01/02/2015 11:43:06 Flag: EGR Electrical Failure, Error 27 changed from Not Set to Not Set..
01/02/2015 11:43:39 Flag: Traction Control (X = Enabled) changed from Not Set to Not Set..
01/02/2015 11:44:03 Flag: Air Pump Diagnostic, Error 29 changed from Not Set to Not Set..
01/02/2015 11:55:24 Scalar: Fuel Cutoff Speed changed from 0.00 MPH (0x00) to 0.00 MPH (0xFF).
01/02/2015 11:55:34 Scalar: Fuel Resume Speed changed from 0.00 MPH (0x00) to 0.00 MPH (0xFF).
01/02/2015 14:39:00 Scalar: Fuel Cutoff Speed changed from 0.00 MPH (0x00) to 0.00 MPH (0xFF).
01/02/2015 14:39:40 Scalar: Fuel Resume Speed changed from 0.00 MPH (0x00) to 0.00 MPH (0xFF).
01/02/2015 15:31:34 Scalar: Maximum Line Pressure changed from 0.00 psi (0x00) to 0.00 psi (0xFF).
01/02/2015 15:31:47 Scalar: Maximum Line Pressure changed from 0.00 psi (0x00) to 0.00 psi (0xFF).
01/02/2015 15:55:34 Scalar: Maximum Line Pressure changed from 0.00 psi (0x00) to 0.00 psi (0xFF).
Changes to bin not saving please help.
