Newbie here.
I'm trying to modify an idle fuel map for larger injectors.
When I change the numbers in the fuel idle map, say presently from 106 to 87, and try to save it, it saves it as 100 instead of 87.
In the bottom of the TunerPro fuel idle map window it says "min 100.000, max
100.00".
Is there something else I have to address?
Changing a minimum value, bin or xdf
