New User Question, 1st time
Techno101
Post by Techno101 »
Ok, so I tried to use Tunerpro RT for the first time and had no clue what to do. I tried to record information but I got a Record Log Error or something like that. Also, on the converter box (USB to ALDL) there is a switch with 3 positions. I switched between the settings and could not get any information from the ALDL dash or anywhere. And, on one position the service engine light would flash and the idle dropped, in the middle ther car would idle normally I guess, and on the last postion the idle went up about 300 rpm. Thanks-
Techno101
Post by Techno101 »
Seems that my ALDL cable is installed incorrectly, as I cannot connect when I test for valid cable settings. I am using a USB converter with an ALDL cable.
