problem w/ datalogging
95blue350
Post by 95blue350 »
I have a 95 c1500 350ci tbi 4l60e. the ecu is a 7427, $od mask, bjym. i have downloaded all of the correct files (i think). i can emulate and can connect with the ecu but can not datalog. nothing shows up on any of the dashes, values, or flags. any suggestions?
downloaded files
od a217 v1.0.ads
$od v2.xdf
bjym od.bin
od v1.02.ecu
riched20.dll
95blue350
oops
Post by 95blue350 »
oops forgot i am using Moates' "Ostrich" that i recently purchased.
You need an ALDL interface cable. The Ostich is a chip emulator. Craig sells the ALDU1, which is a USB ALDL interface cable, or you can build your own serial unit.
