So I have installed 55 lb/hr injectors and a 300lph fuel pump and have the car running pretty good actually. However the ECU seems to be learning fuel trims I don't want and messing up my tune. It takes awhile but eventually the idle gets high and I start getting more erratic fueling.
My O2 sensor adaptation is switched off which I thought shut down the ECU from remembering LTFT's. I also noticed my target lambda is set for 1.3 stock which is weird because I'm not sure why it would attempt to target 19.11 AFR's stock so I am guessing the address maybe off in my XDF.
One thing I did manage to accomplish with all this is getting the injector latency scaling and conversion correct;
http://i107.photobucket.com/albums/m308 ... injlat.jpg
Having the ability to correctly adjust latency helps tremendously. If anyone here can help me out with getting fuel trims in line it would be appreciated and I can email my XDF and BIN to any of you experts who would like to look over what I have and make sure my addresses (Like target lambda) are correct.
Tuning E36 for E85
i can try to help, send me your XDF
alltechmachinery@yahoo.com
