Well this is my first attempt at editing a definition file. What I want to do is add a BLM history table. If you have ever used WinALDL you will understand.
I started with a copy of $42 and then added a new item under history. Row Y axis is RPM, Columns X axis is MAP KPA and for Output Z object I put in BLM.
Not sure of history size or command?
Think it'll work?
Tried the IMG code below but no show? So there's a link to picture below that.
http://www.justih.org/Binder-Bench/atta ... 1297192366
BLM History Table
Well I'll be darned! I ran an old log in TunerPro 5 and it populated the BLM History table I made!
