AFR VS Air Temperature
Today i went on track with my car and the Air temp was around 17*C last week i set the AFR in WOT map to value around 12.5/13 the Air temp was around 27*C today the AFR was Very lean 16/15.3 is it posible to have that big difference by this 10*C temp difference? engine is N/A
He tuned at the higher temp., so when it cooled off 10ºC, it ran lean, which makes sense. The question I have is how is the fuel being metered? Is it MAF, speed/density (MAP). alpha/N?
Dave
Dave
If the MAF is hot wire type, it should compensate for the IAT difference.
