TPv5 RT logging issue
magg
Post by magg »
Asked this question in general discussion without resolutiom, issue might be better raised as a bug.
Need help to understand the best method for repeated start/stop logging without having to shutdown the TPv5 RT application. Problem occurs when a logging period is saved & the laptop is placed in hibernation or standby with TPv5 RT still open. When I return to TPv5 RT & begin new logging session, the new log record includes the time elapsed from the last record saved. This results in a record that can be many hours long before the newl data record period appears at the end of the record.
Was hoping that I would not have to shutdown TPv5 RT application at the connclusion of every logging run.
Comments by some suggestion it has always been an issue with TP5 RT & others say they have not had this problem.
Does this problem manifest if you do not sleep/hibernate the computer between runs?
magg
Post by magg »
Mangus, short answer yes.
Have run a number of senarious & it appears the only time the log record starts at zero time with data, is when TP5 application is closed & then restarted for the next logging session.
Even when a logging session is stopped then saved and TP5 kept running, the next logging session will have a blank data period at the beginning of the log equal to the time elapsed since the last log. Same outcome when laptop placed in hibernate & TP5 remains open.
dfddfd2
Post by dfddfd2 »
Mark,
This is the same problem I reported 6/2309. There are some example XDLs in that email.
Dave
Thanks Magg. That was the piece of information that I needed!
Dave, yes, I have quite a few examples of this and know it exists. I've tried many times to figure out why it's happening, but now I think I have a good idea...
