Two little request thoughts
rob
Post by rob »
When working with TP i wish that the Parameter Window (F2) and Header Info Window (STRG+F2) and maybe every other Window too would close when hitting ESC.
Second thing: When creating xdf's for ecus which are alike but not 100% identical it would be nice to be able to shift all Adresses. For Example i made an xdf for Lancia Prisma Integrale, and i would like to make a new xdf for a Delta GTie, the Map structure is equal for the first couple of maps but start address is $f800 in Prisma and $fb30 in Delta GTie, so i need to shift the maps 816 Bytes up.
I know there is the Possibility in the Header to apply an offset but it would be much nicer to do it once and all addresses get changed and fit.
Is this doable and making sense?
