Hello, I am new to this board, and I want to thank you for a nice looking program.
I downloaded the free Tunerpro program and also some bin's from the Moates download page, and my question is why does nothing happen when I try to open the binfile in the Tunerpro program ?
I am using Vista, could that be the problem ?
I also downloade an .XDF file just to check and that I can open.
Thanks in advance
Marco
Vista problem ?
- Pavement Pounder
Vista problem ?
Last edited by Pavement Pounder on Sun Mar 29, 2009 7:42 am, edited 1 time in total.
- Six_Shooter
Not a bug or a problem from what I read.
You need to use an XDF to view what's in the bin.
The XDF is essentially a road map to what is contained in the bin.
The XDF contains the information of where the tables are located in the bin along with how large they are, along with just about every other variable in the bin that you would need to adjust.
So you need a propper XDF that matches the bin you are using, to view the bin and adjust properly.
