Motronic M2.7
edkmho
Motronic M2.7
Post by edkmho »
Hi all expert and guru,
Has anyone tried TunerPro with Motronic M2.7. I am looking to tune a Fiat Punto GT 1.4 (Turbo) with this particular ECU. Hope someone can shed some light in this matter.
Thanks.
tom
Post by tom »
I also wanted XDF for ME 2.7 from VW Golf VR6, anyone help me??
revlimit
Post by revlimit »
Motronic ecus from early 90s for VW are easy. I looked at the VR6 motronic 2.8 bin file and it looks similar to BMW.
However every ECU has its own bin file and XDF file would have to be authored for each bin file, it is not one fits all like nissan ecu
tom
Post by tom »
revlimit wrote:Motronic ecus from early 90s for VW are easy. I looked at the VR6 motronic 2.8 bin file and it looks similar to BMW.
So if it easy, could you help me?? I try tuned file from VW Corrado 2.9 with Motronic 2.9.1
revlimit
Post by revlimit »
So is this what you have?
Golf VR6 2.8 litre (AAA)
94-95
Bosch Motronic 2.91
0 261 203 222
021 906 258 BM
0 261 203 223
tom
Post by tom »
My bin is from VW 2.9 with Motronic 2.9.1
021 906 258 AG number ECU
revlimit
Post by revlimit »
I can't help you , you are not providing any information on to what I need to help you with.
edkmho
Post by edkmho »
revlimit,
Any idea how to go about with the Motronic M2.7? Please help
revlimit
Post by revlimit »
These are done and will be posted soon in Definition page
tom
Post by tom »
I know where is rev limit in VR6 soft 0 261 203 219 (adress in hex CF00-CF01) but I don`t know formula, anybody help me??
revlimit
Post by revlimit »
so if it is two bytes, that is 16bit, then you got to know the stock rev limit cutout, 6500 for example then you use basic math to found out calculator of the 16bit data to match the stock rev limit. And this can be put into definition file.
x_system
Post by x_system »
Hi, i'm searching for 0 261 203 210/211, 021 906 258 CG .bin file, from vw passat vr6 2.8 engine with 4 wire MAF and 5 wire coilpack, could anybody help me ?
zioweb
Post by zioweb »
it works like a charm with the punto gt!!!
Power On The Road Equipped
...I always do by myself...
gkoutsis
Post by gkoutsis »
I think the boost control xdf is incomplete. There are 2-3 maps missing and also the ones defined have a few mistakes.
gkoutsis
Post by gkoutsis »
Looking for the injector constant for a GT2 with 841 ecu?
Any ideas guys?
