fuel correction
fuel correction
newby to this arena again , i put in a post before but i cant see it so i probably screwed that up too. problem is i have an 808 ecm with a 27c128 memcal i am useing an $FB XDF and i have to increase the fuel injector open timing to run on methanol, i cannot find the appropriate area to access the MAP/TPS/or RPM fuel curves can someone point me in the right direction please
