Logging with ostrich 2?
I was poking around looking at some BMW stuff on this site(I have a 95 m3 I plan to tune eventually) and saw someone say you can do some logging with an ostrich 2 with tunerpro. Is that something I can do with a 7747 ECM or only the BMW stuff?
- Six_Shooter
That was probably address hit tracing that was being discussed with the BMW, since they don't have an ALDL connection, like the GMs do.
I'm sure it could be used with the '7747, but I've never tried it, since I have an ALDL cable. I also have read that it's not as good as using an ALDL cable.
If you are asking specifically about the table tracing, yes this can be done with the '7747 and an ALDL cable, just needs some items set-up, if your XDF isn't already set-up for it.
- Six_Shooter
It really is the easiest way to get the data you need, that can't be see in address hit tracing and to get tracing to work.
Just as an FYI, your XDF might need some simple editing to get tracing to work. I find that not many XDFs have the X and Y settings set-up, that I have downloaded.
Did you get the Ostrich to connect more reliably now? I haven't seen an update to that.
I haven't had a chance to try it. I have been helping a couple guys from Canada with their Grassroots Motorsports $2010 Challenge car. I dyno tuned it on a local dyno last night and today was the auto-x. Tomorrow is the drag race and they want me to do most of the runs and I also have to do a quick tune on another competitors car. Busy few days. Lol. Maybe Sunday or Monday.
- Six_Shooter
- Six_Shooter
- Six_Shooter
There was a pretty badass white one with a turbo. It sounded insane. I am about to build a 91 civic hatchback for next year. Gotta get this truck tuned to tow it though. Lol
Speaking of the truck. I got a new ostrich cable cause I was having some problems with hondas too. That seems to have fixed the problem.
Now I'm having trouble logging. I ordered the aldl setup through moates at the same time as the ostrich cable. Tunerpro says it's connected but I can't get it to show me anything and it also says mismatched xdf ads file. Any ideas?
- Six_Shooter
I wouldn't worry so much about that mismatch warning, it may be an issue, but all it is telling you is that the ads, that you are using has a different name than what is saved in the xdf as the "matching" ads.
Lets just go through your set-up just to be sure everything is correct:
Tuner Pro RT version? (I believe it's V4.14, correct?)
XDF you are using?
ADS/ADX you are using?
Com port set correctly for the cable? You can use "Verify cable" button to make sure, just don't have the cable plugged into the truck, when you use this test.
The issue with the 160 baud datastreams, is that you can have no cable connected to the laptop, and have "connected" show up in the taskbar.
XDF you are using?
- Six_Shooter
It possibly may need to be edited.
In each table, you can highlight then hit F2, to bring up the box that allows editing of that table. The last tab, will have "ALDL Association." You will see in this tab, drop down menus to select the X and Y axis association. You will need the ADS loaded at the same time.
- Six_Shooter
ok, here is a screenshot of where i end up following your directions. it wont let me put anything in the x or y boxes(not that i know what needs to go in there anyway) lol
ok, so right after posting this, something caught my eye that i read trying to figure. i remember reading that it cant be set to "string". i changed them to "floating point" and then it allowed me to set it for RPM and MAP. cant wait to see if it works now.
- Six_Shooter
Hopefully this is the last thing. Lol
Is it possible to log my lc-1 through the narrowband wire? Trying to glance back and forth from the wideband and cell tracing is tough.
Or is there some other way to log the wideband?
I have tried searching to see if I could log with logworks through the ALDL cable and can't find much info. I don't think it's possible to log the wideband through the serial port with tunerpro either is there?
- Six_Shooter
Yes, the quick head snap back and forth.... then remembering....
Yeah, not fun.
There are ways to log the WBO2.
Most people use the EGR input and connected to the 5V output of the WBO2 controller, then edit their ADS/ADX to change the EGR values to WBO2 values.
Another way that I have thought of, but haven't tried it myself is to change the 5V output to a 1V linear output and log through the NB O2 input. The ECM would NEED be in open loop, otherwise the ECM will try to compensate for the voltage changes. Again, this is only theory, I have dones some initial testing on my test bench, but haven't needed to use it in car, so I haven't verified 100% that it would work yet. The ADS would also need to modified to show true AFR in relation to the voltage input.
Yeah, not fun.
