Hi everyone
i have a problem with a 403 ecu mixture getting very rich after engine warms up (using very big injectors but decreased injector constant so the tables are manageable)
Is there a table related to fuel enrichment and engine temperature?
Thanks in advance
403 temperature fuel enrichment problem
Re: 403 temperature fuel enrichment problem
Hi,
What did you put as injector constant value ?
Can you show us the parameter of your table XDF Injector constant ?
Hi sorry i was busy due to the start of race season
Injector constant was put at 18500( raw data)
(varies depending on the injectors used. Mine were volvo s40t on m50 turbo)
Xdf address was 6a16 (16bit)
