tunerpro wont open
tunerpro wont open
Hello all, I've just installed tunepro rt on my windows 10 computer and when I try to open it the tunerpro icon pops up but says no hardware found and fails to open? Any ideas why? the download did finish and I didn't get any errors on the install so i'm lost.
Re: tunerpro wont open
I am having the same issue. I had an older version on a Windows XP laptop and had a motherboard failure. Now I am on a Dell M4600 with Windows 10 and the latest TunerPro. When I try to open I get the logo and then it goes away and nothing happens. I've tried running as admin and in different compatibility modes. Any ideas? Thanks.
Although it's installed with the TunerPro installer, some systems might fail this step, so you should try installing the Visual Studio 2017 redistributable manually. Here's the link:
https://support.microsoft.com/en-us/hel ... -downloads
If you're running a 32-bit OS (your Windows XP build is likely 32-bit) then install the x86 version. If you're running a 64-bit OS (a Windows 10 installation is likely 64-bit), then run the x64 installer.
-Mark
-Mark
Mangus what do I do if this doesn't work ?
It looks like I'm having the same problem. I get the splash screen, then nothing.
Anyone figure out a solution? I'm in the same boat. The splash screen pops up, but the app itself never starts. Windows is not my usual OS, so I'm not quite sure where to poke around
- Windows 10 Pro, all current updates
- Visual C++ 2015-2019 redistributable installed
- Latest TunerProFree from the website
Turns out I needed to install the Visual C++ 2010 package. Now that I've installed that the app fires right up!
tdjb, glad to see you found a solution for your install problem and thanks for posting it.
