Can't Connect
Motors
Can't Connect
Post by Motors »
I know there are many can't connect strings... but none I've read have fixed my problem.
1986 1227165, $32b, 1224165_160.adx All loaded
Using serial/usb cable with 10ohm pins shorted. Have used this cable before with successful connection using dataMaster never TunerPro, although never really a certain connect without several attempts
Now using Tunerpro RT Ver 5.0
Preferences set to use Plug-in, TunerPro Data Acquisition I/O Interface, Standard Serial, Com 4
Win XP, Comm Port 4 set to USB cable and active, Checked using Control Panel
Test for Valid Interface.... Returns Cable Active
Turn on ignition, click connect, DA Connecting displays but connection does not occur and no data is received.
I have edited the Acquisition file adding reporting elements to the dashboard.
What have I missed...???
Help!!
