Update Hyundai Tucson ECU?
wattaman
Post by wattaman »
Hi,
I've just found this software using Google and before I'll dig into the 'how to' and the documentation, can I know if this can be used to update/upgrade the ECU on my Tucson? Or reinstall the same maybe?
The main idea is that my mechanic blames the ECU for car overboosting, so I'm thinking that maybe a ECU update will fix it (if this is really the issue). And since this software is free and a obd cable should be cheap, maybe I can try this before thinking about replacing the ECU.
Thank you.
