Ostich 2.0 emulation - wrong file when verify with EPROM burner??
AK16
Post by AK16 »
Hallo,
last year my Ostrich 2.0 works fine.
Today i have put it again in my car. The car does not start.
Ich have put the Ostrich 2.0 on my EPROM Burner.
When i read the file with the burner from the Ostrich 2.0, it is not the same i have laoded up in TunerPro RT. ??
I save the wrong data form the EPROM burner in a bin file. Than i laod the wrong file in TunerPro RT to the Ostrich. When i read out this file with the EPROM burner, it is matching with the uploaded file in TunerPro RT.
I have testes this on 2 Laptops. Same issue.
What is this? Can anybody help?
AK16
Re: Ostich 2.0 emulation - wrong file when verify with EPROM burner??
Post by AK16 »
next test:
the EPROM burner reads everytime the same data from the ostrich, it dosent mather what i laod with tunerProRT into the ostrich 2.0.
If i press "verify" in TunerPro RT -> sucsess.
For TunerProRT the data is in the Ostrich - but the EPROM Burner reads out always the same wrong data.
AK16
Post by AK16 »
i have solved the problem:
-may be i have change position of the switches
or this:
http://support.moates.net/troubleshooting-switches/
-Fortunately, the solution to switch glitching is really easy. Sliding the switch back and forth vigorously 5-10 times has been successful in restoring normal operation.
AK16
Post by AK16 »
...same problem again. :-(
I upload a file in TP RT to the ostrich, verify: ok.
Ich download the file from the ostrich - it's not the same i have upload.
-switch move many times, same problem
-disconnects the ribbon calbe from the ostrich, same problem
-an other USB cable, same problem
-an othe Laptop, same problem
any ideas?
AK16
Post by AK16 »
i have figured out:
1.
-upload in TP RP 64KB file
-download data with TP RP -> wrong data, only 32kb download
This is in all 4 posible switch configurations.
2.
-upload 32kb file
-download -> right data!
maybe there is something wrong with the switches?
Any ideas?
AK16
Post by AK16 »
I have e-mailed moates support.
Now it works. In XDF Header i have changed "bin size" to 0x10000.
Now it works.
I have never changes this value. So i wonder how it works bevor with wrong setting.
