I´m having a really hard time developing xdf file for the same ecu at different softwareversions. I´d like to incorporate 176 scalars for dtc handling and putting those in manually each by each is a pita!
Is there any way to select more then one table/scalar/... at once which i haven´t found?
Not possible. However, if they're all very similar, create one scalar exactly as you want it, then copy it (Ctrl + C) and paste it (Ctrl + V) to make a copy. Then do a quick edit of the copy.
thanks for your information. I got it by using Windows Editor. In first time i didn´t checked the xdf files could be tweaked by Editor as i just used my locked files. By using unlocked files i got it sorted.
