Data Acquisition for Lancia Lancia_v1.adx
Discuss all other manufacturer-specific tuning topics here. Request definitions, discuss parameters, etc.
zioweb
Post by zioweb »
Hi all,
I've downloaded from the tunerpro site the file Lancia_v1.adx and want to use it on a Coupè 2.0 16v turbo.
How can I interface the PC to the ECU for Data aquisition?
I need a particular ALD interface?
Power On The Road Equipped
...I always do by myself...
hnracing
Post by hnracing »
Do a search on ebay for
"obd2 usb vag kkl" and
"Fiat Lancia Alfa RomeoOBD2 Diagnostic adapter "
BR
rob
Post by rob »
Currently this Adx expects only one Byte in Return! All the KKL Interfaces i've seen echo the sent data! So you will very likely get garbage.
Solution 1: Modify the KKL Adapter.
Solution 2: Modify the ADX and send it to Mark with a different name (Lancia_v1_KKL.adx for Example).
ROB
hnracing
Post by hnracing »
Just go
Acqusition ->Edit definition ->ADX Header Data
- check the box for "RS232 Echo"
Save
Done!
zioweb
Post by zioweb »
thank U very much for the explanation, this sounds very good to me because I have the kkl interface and the 3 pin adapter :)
thank U very much!
maxim
Post by maxim »
dear friend I know this topic very old.
I need some help about marelli P8 ecu.
I can not connect over tunerpro5 with Lancia_v1_1.adx to ecu.
4W6/P8 alfaromeo 155Q4 ecu (like lancia 16V)
-I have original lancia tester diagnostic, its work well
-Im registered tunerpro user and I have ostrich 2.0 emulator, its work well
-I have 409.1 KKL usb interface and 3 pin fiat cable,
its work well with startrek software on notebook from "nailed barnacle"
finally evey devices are working but Lancia_v1_1.adx NOT.
Im set it correct com port in configure menu com6
but tunerpro give me an error when I test.
"TEST FOR VALID INTERFACE USING SETTING" -> cable not found or not functioning.
midnight_man
Post by midnight_man »
anybody tried this adx with elm327?
