closed loop tables?
Discuss DSM (Mitsubishi) definitions here
carlhunguss
closed loop tables?
Post by carlhunguss »
i was wondering when you extend the fuel map can you push back the open loop to what ever rpm you reach you 4.1 gm per rev? if so how would you go about changing the rpm range in tuner pro? my car is a 1g auto with a little way to big turbo . it dosn't spool till the top of second gear. that leaves me with a map that i want to extend to 8k in first gear for sure . how do i tune my car for first gear that has no vacuum or boost ? thanks 4 reading :shock:
