JPA1 bin for '97 V6 Mustang
David Claflin
Post by David Claflin »
Does anyone have one or know where one can be had?
1990LX 306, 77MM Pro-M, 75MMTB, Holley SystemaxII, Neil Erickson ported Edelbrock performers, 1 3/4"BBK longtubes, T5, 3.73's, Mach 1 disks, 18.5 city 27 hwy, Moates chip, Tuner pro,334RWHP/351RWTQ
David Claflin
I found the CDAN XDF, but still not sure what to use for a BIN. Any suggestions??
E-mail sent.
rpsucilla
Post by rpsucilla »
dex wrote:E-mail sent.
Hi can help me with these bin too? have a ford mustang 97 ecu JPA1 I´ve try to read usin the flash and burnII + FA + FE but I can´t be read good because the xdf show me wrong parameters
Thanks.
If you cannot get a good read then the J3 connector may require cleaning.
rpsucilla
Post by rpsucilla »
I´m sure the J3 por is clean because the file always read full 256kb.
only the first time read 56kb, can i upload my bin to you could check it?
Regards.
TunerPro will always read the bin size you set it to but if the J3 is not clean it will read garbage. In addition to the protective grease most J3 connectors are protected with a clean conformal coating.
