$6E Hack
Burb
$6E Hack
Post by Burb »
Hi, Mangus, first of all I want to thank You for developing tunerpro, its awsome. I am having trouble with the address correlation, in editing the ECU file. So I was wondering if you still had the $6E Hac, that you used to develop the 6Ev010 ECU file. I am having a hard time finding it.
I am trying to build an ECU file for the $OD mask, but doing a cross reference of the $OD Hac, and your 6Ev010 file, is blowing my mind. If you could help in any way, such as pointing me in a direction, that I could obtain the $6E Hac, That would be extremely helpful. Thank You Sir 8)
the 6E hack (nor the 6E ECU file) won't help you create $0D ECU. You need the $0D hack, which is out there. Google it. $6E is out there, but a little harder to find.
Burb
right on mark
Post by Burb »
AHH, but it will help me to understand how you put the 6E file together and will show me how to correlate the addresses. which is what I am working on, so that I may create the $OD ECU. So, obscurely, it will help me a lot. 8) Thanks Anyway Mark...
