mefi 4b ground
drive805
mefi 4b ground
Post by drive805 »
have a sandrail with a shortstar v6 mefi 4b believe i lost ground could i run and ground from case bolt to chassis
cbernhardt
Re: mefi 4b ground
Post by cbernhardt »
What is this "case bolt"? Do you mean the MEFI4b case?
I have an MEFI4a and the wiring harness has several ground wires. I am assuming that the MEFI4b harness is the same, so I would suggest using these harness ground wires and connect them to a good ground.
