Healtech Obd and Tuner pro RT
Hi everyone, I'm trying to tune the fuel in a Kawasaki 1500cc engine with a turbocharger. The engine is from a Jetski. I have a Healtech OBD device that I connect to the ECU. Unfortunately, the logging controller doesn't provide information like injection timing or ignition advance. However, it does provide RPM, TPS, and Load Map. I have the original BIN and XDF files from this controller. I was thinking about using Tunerpro RT to see where I'm at on the fuel map, etc. Unfortunately, I'm missing an ADX file. Could anyone help me create an ADX file for the Healtech OBD? Nothing comes for free, of course. It would be a great alternative for Healtech users. I also have an Innovate LM-2, but it unfortunately has problems with stable RPM readings from the CDI. By the way, will the ADX file for the LC-1 be compatible with the LM-2? Regards.
