Multi select item for sync
845motorsports
Post by 845motorsports »
It would be awesome if you could select an item then hold control and select another one so you can add more then 1 at once.
also if possible have the ability to sort the list in alphabetical would make things easier to find :)
TIA
Re: Multi select item for sync
Thanks!
845motorsports
thank you for all the hard effort you put in!
