ADX History table
Matrix
ADX History table
Post by Matrix »
I would like to have the ability to exclude some data if certain conditions are met in an ADX history table. For example I have a History table that is Load vs RPM vs injector pulse width. I uses this table to create a new main fuel table due to engine modifications. I find that when fuel cut is enabled the zero injector pulse width values skew the results for that load/RPM point. If I was able to exclude data points where injector pulse width = 0 then the results would be much better. I have tried using averages etc. but the suggested feature would be very useful.
Unless there is another way?
Re: ADX History table
Yes, I agree, this has been on my list. Thanks!
Matrix
Post by Matrix »
I look forward to this feature. The other option I have thought of - provide an import feature of the CSV file. I could export the log file to csv, manually filter out the values not wanted and then import csv back to log file and replay. This would achieve the same result.
