Virtual Readings
JP86SS
Virtual Readings
Post by JP86SS »
I would like to have the ability to create a "virtual" item in a datstream display that is based on a calculation of two other items.
EX: Commanded AFR (actual reading) - WB AFR (actual reading) = Vitual result item (AFR Correction)
Basically would need to be able to create the item without a packet offset address so it wouldn't throw errors when trying to display.
Maybe this is already possible with the "linked" items but I haven't figured out how to do it. :oops:
Kinda translates the need to SP too.
In ScannerPro this is already possible. See the Fuel Efficiency item in the 6E.adx.
JP86SS
Post by JP86SS »
Mangus wrote:In ScannerPro this is already possible. See the Fuel Efficiency item in the 6E.adx.
Will do :)
Thanks for the new TP version too!
JP86SS
Post by JP86SS »
Super cool!
Didn't realize to make static items like that for calculations.
Used it in my $8D and it showed 22 MPG w/o Hiway mode on.
(Holy milage Batman, I used to be around 10 on a good day)
