I'm trying to import a large number of parameters into an XDF file from a delimited text file - see attached for a trial file with one parameter. The scalar gets created, but none of the other information is loaded.
Is there something I am doing wrong? I did notice that the XDF Header has a default Bin size of 0000 - not sure if that is causing a problem or how to fix that.
Any help would be appreciated.
Struggling to Import XDF from Delimited File
- Book2.zip
- (377 Bytes) Downloaded 1480 times
Re: Struggling to Import XDF from Delimited File
For a scalar, you need to use the "Z" attributes, e.g. ZOffsetInt, ZSigned, ZUnits, ZLSBFirst, etc.
I really need to document that importer. =(
Thanks!
Is there a way to import Row and Column Labels and assign Data Type and Stock Units?
lesexypaul82
