Bosch MD1CE101 ecu remapping using TunerPro XDF
Discuss all other manufacturer-specific tuning topics here. Request definitions, discuss parameters, etc.
New TunerPro bin calibration file (XDF) for all vehicles (trucks, tractors, construction machinery, spec. app, boats) with engine control unit Bosch MD1CE101.
Some of the supported TRACTORS:
Case IH Combines
Case IH Magnum
Case IH Maxxum
Case IH Optum
Case IH Puma
Case IH Steiger
Case IH Steiger Quadtrac
Case IH Vestrum
Claas Axion
Claas Arion
New Holland CR Series
New Holland CX Series
New Holland CH Series
New Holland FR Series
New Holland T5 Series
New Holland T5 S Series
New Holland T6 Series
New Holland T7 Series
New Holland T7 S Series
New Holland T8 Series
New Holland T9 Series
New Holland TC Series
Steyr Absolut CVT
Steyr Expert CVT
Steyr Impuls CVT
Steyr Profi Series
Steyr Terrus CVT
Arbos Series 7000
Bourgoin Harvesters
Horsch Sprayers
Landini 6 Series
Landini 7 Series
Some of the supported TRUCKS, BOATS and CONSTRUCTION MACHINERY:
Iveco S-WAY (all versions)
Iveco FPT Marine Curson (all versions)
Case IH Graders (all versions)
Case IH Wheel Loaders (all versions)
New Holland Wheel Loaders (all versions)
Some of the supported SPECIAL APPLICATIONS:
Case IH Farmlift
FPT Industrial Gensets
FPT Industrial Soundproofed
Faresin Ecomix
Faresin Leader
Italmix Matrix
Italmix Rover Jumbo
Italmix Rover Jumbo Up
Konrad Highlander
New Holland Braud
New Holland TH
Triolet Feed Mixer
TunerPro available maps
- Injection Limitation: curve for fuel quantity limitation after cold start, injection quantity based limitation curve.
- Injection Quantity: dynamic calculated injection mass (MAP strategy), injection mass at high temperature, injection mass at low temperature, injection mass at maximum temperature, injection mass for engine protection, desired fuel quantity map for open loop logic, desired fuel quantity map for signal defect condition.
- Injection Time: map for conversion of injection volume to energizing time.
- Fuel Conversion from Torque: engine basic map for conversion of torque/quantity.
- Smoke Limitation: map to determine the lambda value of smoke limitation.
- Torque: torque limiter by atmospheric pressure, torque limiter speed dependent, torque limiter by fuel temperature, limiting torque curve in the event of system error, curve for torque limitation, curve for engine speed limitation in case of system errors, curve for normal engine speed limitation (inner engine torque).
- Rail pressure: basic fuel pressure setpoint, fuel pressure setpoint maximum limitation, precontrol map for pressure control by the pressure control valve.
- Boost: map to determine temperature corrected charged air cooler pressure value, reference boost pressure map.
Price 70 euro.
Post: https://oldskulltuning.com/bosch-md1ce1 ... erpro-xdf/
