Export Datalog to CSV
soccerball49
Post by soccerball49 »
I collected an XDL file using Scanner Pro and I'm wondering if I can use the TunerPro RT export function to write it to CSV. I tried it out and it translates the column headers but no data is shown. Am I doing something wrong?
Re: Export Datalog to CSV
Use TunerPro RT instead of Scannerpro and then you can export your datalog to a .csv file.
soccerball49
Hi dex,
Thanks for the reply. Unfortunately I do not have the option to recapture the data. I only have the XDL file that was captured.
I can load the XDL file I captured using ScannerPro into TunerPro RT, but replaying the data doesn't show anything and the export to CSV only gives me column headings, but no data. I have the ADX file loaded and nothing else.
Is there any work around?
