Table Copy/Paste from Google Sheets
bubba2533
Post by bubba2533 »
I cannot copy and paste from google sheets into a table.
I believe excel works, but my subscription has expired and I really don't see a difference for what I use it for.
I updated to the latest version of TunerPro to make sure it was not because I was on and old version and it still doesn't work.
Re: Table Copy/Paste from Google Sheets
I'll look into it. Sounds like Sheets uses a different clipboard formatting.
bubba2533
Post by bubba2533 »
An interesting addition is that I am able to copy and paste values into the row/column labels fields when editing a parameter, which I just realized.
When pasting it skips the last cell though.
Andre Chee
Post by Andre Chee »
A workaround that might help is copying the data from Google Sheets and pasting it into a plain text editor first (like Notepad), then copying it again from there to your table. This often removes any hidden formatting that causes problems.
Besides this, I'd recommend optimizing all your operational processes to avoid any unwanted cases that will make you responsible for some damages. To gain a better understanding of operational management, you can read this example of a bottleneck analysis. There, you'll find detailed info on how to find problematic processes and how to optimize them. Check out here https://www.crispysoftwaresolutions.com ... management .
This should be fixed now, as of build 5.00.9786.00. Is it not?
