30lb Injector offsets?
v8garage
Post by v8garage »
I haven't been able to find calibration sheets for my Bosch 0280-158-193 30lb injectors. Looking for suggestions of what values to use for tuning?
Jim
1953 Ford F100
5.0 H.O. from '94 Mustang GT
AFR 165cc Renegade Heads
XE274HR-12 Comp Cam
BBK SSI Intake
30lb Bosch injectors
Pro-M 75mm MAF
70mm Throttle Body
T4M0 ECU
Motorhead
Re: 30lb Injector offsets?
Post by Motorhead »
I wonder how similar they are to the 31lb 0-208-155-831
v8garage
Post by v8garage »
Those look to be rated at 31.8 lbs/hr at 55.1 psi?
The Bosch units I have are stock Ford injectors for 2010-2016 E150-350 5.4L. I had them cleaned and they flow tested 30.2 lbs/hr @ 39.15 psi. I was thinking of using the Ford Performance M-9593-B302 battery offsets as the high slope values are very close?
1953 Ford F100
XE274HR-12 Comp Cam
BBK SSI Intake
Pro-M 75mm MAF
70mm Throttle Body
T4M0 ECU
decipha
Post by decipha »
Correct, 30.2 lbs at 40psi is what I have as well.
The info is on my website.
http://www.efidynotuning.com/injdata.htm
