ostrich problems?
scrappy
ostrich problems?
Post by scrappy »
Whenever I start my car after sitting for a few hrs, the car runs like it has no chip in it and I have to re-upload to the ostrich then all is fine. are the batteries dead or do I have another issue?
scrappy
Post by scrappy »
Its not the batteries, it is still doing it with new batteries
If you re-upload and it runs fine - does it stop running correctly if you don't make any changes to the bin, then let it sit? If so, it could be a hardware problem, and Craig can get you squared away.
scrappy
Post by scrappy »
Mangus wrote:If you re-upload and it runs fine - does it stop running correctly if you don't make any changes to the bin, then let it sit? If so, it could be a hardware problem, and Craig can get you squared away.
when I restart it runs on the limp program on the stock chip, when I reload the bin it goes back to normal. it doesn't matter if I change anything or not, the result is the same.
I am now in contact w/Craig to figure it out.
