Second generation XDF for Nissan 350Z Fairlady with ecu Hitachi SH7058
Discuss Nissan tuning topics here. Request definitions, discuss parameters, etc.
Available maps:
- Fuel: fuel compensation during acceleration, fuel compensation during deceleration, fuel compensation, fuel compensation for high coolant temperature, target afr, target afr (knock), fuel cut, fuel restore, crank fueling by engine temperature, injection time.
- Ignition: basic spark advance angle map – cold, basic spark advance angle map – main, basic spark advance angle map – high detonation, knock sensor threshold.
- Air Control: MAF.
- Torque: estimated torque delivered.
- Temperature: simulated exhaust gas temperature.
- CVTC: intake, exhaust.
- Idle: idle engine speed by temperature.
- Throttle: target throttle valve opening, target throttle valve opening – calibration.
- RPM Limiters: RPM limiter – cut, RPM limiter – restore, RPM limiter – reverse – cut, RPM limiter – reverse – restore.
- Speed Limiter.
Post: https://oldskulltuning.com/nissan-350z- ... erpro-xdf/
Price 70 euro.
(balance difference price should be paid by the customers how already bought the relevant xdf).
