def files??
Locked
Tricked-Out-Toy
def files??
Post by Tricked-Out-Toy »
iI just downloaded the software and webt to the def file link and there wasnt any def files for download? I need the $EE file.
Joshua Angley - General in the Thirdgen Mafia
LT1 LE3/LE2 HC, T56, LS1 rear 3.42, C5 front brakes, Longtubes w/ 3" over axle duals. Its cute http://www.cardomain.com/ride/2108104
I just uploaded a sample definition. It's up to you to fill it out with the rest of the values, etc.
Remember, ScannerPro is still under development. It's not ready for general use by people who are just getting started (as you might have surmised from the download agreement). There's going to be a lot of leg work on the user's part in order to flesh out definitions, etc.
Tricked-Out-Toy
Excellent! I connected no problem. I was only briefly able check it out and its ALOT nicer that datamaster! I wont be able to do much more with it till later in the week. I was having some connection issues when I disconnected and then reconnected. it would flash between error and connected, not sure if that was something I was doing or not. once I shut it down and restarted it connected fine. just had the issue when I clicked dissconected then reconnect after the car was running.
Also I did see anything that showed the AC pressure voltage? did I miss it? I use that for my wideband output and convert the voltage to AFR.
thanks for the EE!!! I know alot of ppl will be looking forward to see another option out there for data logging our lt1's!
You'll have to add any missing data. It's not a complete definition. I used it as a test to make sure I could successfully connect to EE. Feel free to complete the definition and send it back to me.
Tricked-Out-Toy
Sorry bro, I wish I knew how to edit a def file. I wouldnt mind learning but as far as adding info to it I dont think i could be to helpful...
Tricked-Out-Toy wrote:Sorry bro
No problem, chief.
Locked
