Mazda 2.0L SkyActive G tuning Denso xdf
Discuss all other manufacturer-specific tuning topics here. Request definitions, discuss parameters, etc.
New TunerPro bin calibration file (XDF) for Mazda 2.0L SkyActive G (PE-VPS) with engine control unit Denso.
Supported cars (engine code PE-VPS):
Mazda 3 (BM/BN) 2.0L
Mazda Axela (BM/BN) 2.0L
Mazda 5 (CW) 2.0L
Mazda Premacy (CW) 2.0L
Mazda 6 (GJ/GL) 2.0L
Mazda Atenza (GJ/GL) 2.0L
Mazda Biante (CC) 2.0L
Mazda CX3 (CW) 2.0L
Mazda CX4 2.0L
Mazda CX5 (KE) 2.0L
Mazda MX5 (ND) 2.0L
Mazda MX5 RF (ND) 2.0L
Mazda Roadster (ND) 2.0L
Mazda Roadster RF (ND) 2.0L
Available maps:
- Fuel: fuel part throttle (safe), fuel part throttle, fuel full throttle, fuel enrichment, fuel egt enrichment multiplier, maximum fuel enrichment afr low speed, maximum fuel enrichment afr high speed.
-Ignition: minimum ignition timing, ignition timing high load, ignition timing low load, ignition timing cold engine, maximum allowed ignition timing.
-Torque: actual calculated torque, torque at full throttle.
- Throttle: throttle.
- VVT: intake cam timing low speed, intake cam timing high speed, intake cam timing, exhaust cam timing main high speed, exhaust cam timing main low speed, exhaust cam timing.
- Temperature: expected exhaust temperature, expected exhaust temperature – safe limits.
- Direct Injection: direct injection pressure, direct injection pressure low load, direct injection pressure high load.
- MAF: MAF sensor scale.
- Special Functions: RPM limiter, Speed limiter.
Post: https://oldskulltuning.com/mazda-tuning ... erpro-xdf/
Price: 50 euro
