М50В25 turbo 440 cm injectors constant help needed
Olegonic
Post by Olegonic »
Hello
Need help here
I ran my engine with 250 cm injectors before and it was not enough after 4K RPM and 0,9 boost
Injector constant was 54909
I have changed to 440 cm green BOSCH injectors and cannot start the engine
I have tried different constants from 54800 to 53000 but it doesn’t start
I can hear combustion goes on sometimes but not enough
Can you please help me with what INJECTORS CONSTANT I should set
I ran Cobra RTP emulator = motronic online and MAF emulator = MAP sensor (MAF deleted)
DME Bosch 402
Tuner Pro
BMW E30, M50B25 NV turbo
Olegonic
Re: М50В25 turbo 440 cm injectors constant help needed
Post by Olegonic »
Found out the correct injector constant without “GURU” help here
Another problem, when engine is hot, I have to run starter for 7-8 seconds in order to start the engine
Cold start is OK
Where to look?
märt
Post by märt »
Hey, I dont know much but this guy does.
https://www.youtube.com/watch?v=InZPdmn ... iC&index=3
Also check out his m50turbo build, he explains a lot tuning in some of the videos, just use the playlist function on his channel and you'll find it there.
Hope it helps even a little.
