saving log files
vwnut8392
saving log files
Post by vwnut8392 »
the way its currently laid out for saving logs is a little bit tedious if im working on the street with gathering logs. would it be possible to put an option in the preferences part where to save all logs like (my documents/tuner proRT/my logs) folder for a default than when you stop log instead of getting the save log window pop up the log just gets a date and time stamp name automatically with a small prompt that says "log saved!"
Re: saving log files
Thanks for the suggestion.
ben73
Post by ben73 »
I just came here to make this suggestion also :)
Also, because the .log files are stored with the .bin files, when you load a new .bin, TunerPro doesn't filter the file types in the popup window so it's possible to load a .log file in place of a bin. Easily done when you are out driving with the laptop on the passenger seat in bright sunlight.
This gets pretty ugly when you are in emulation mode and the engine craps out on the side of the road! :)
