Hi Guys
Has anyone had a hack at a 2 bar 5D (say BAAM) in a '808/'082
Im running a twin turbo v6 with vapor lpg injection @ 10psi but am running out of map resolution.
Any thoughts???
2-BAR 5D Hack ....Now $12 Hack
Hi
Since I posted this question I have gone to a $12 file using a 082 (like a 165 with 8192 baud) The $12 file has High and Low rpm VE maps Low RPM is from 400 RPM to 2400 RPM and High RPM is from 2400 RPM to 7200 RPM with normal MAP range 20 KPa to 100 KPa with 100 being no VAC and 20 being full VAC. But using a 2 bat MAP ( 1 bar boost and 1 bar vac ) and with MAP resolution from 20 to 100 no 200 it makes the 1 bar boost mark 100 and the no vac or 0 boost 60. and the same problem hapens in the Spark maps also. I have seen some 2 & 3 bar hacks to the 730 and they now have MAP resolution from 20 to 200 KPa with around 100 being the 0 mark on the boost gauge. I have been through the $12 bin and converted it for LPG and done a rough remap for 1 bar boost but more MAP resolution is still needed. is anyone able to point me in the right direction for this???
Justin
Justin
