Hi
I'm on a quest to reverse engineer bin files to learn more about software and also engine functions and getting live data from parameters. Looking to do an electronics project starting with a OBD scanner which can get live parameters of a particular model of car that I like.
Anyone experienced with ECM hardware and software could explain why a ECU part of a certain model/series of a year (ie excursion or super duties) would have so many software updates? what's the difference between all the versions that I would expect to appear?
here's some sources I found yesterday:
https://www.fs1inc.com/oem-engine-co...itional_tabbed
Ford firmware update database
thanks for your advice/opinions
expert advice needed on software update versions of OEM ECU
