'89 3.1
'89 3.1
I have a '89 Olds cutlass (W-body) 3.1 I have installed 17 lb/hr injectors (stock is 15). It works ok, but the blm's are right around 100 and once in a while it will set a too rich code. Sometimes its hard to start. I would like to change the injector constant. Can I use the definition for the turbo grand prix? I would think the map values wouldn't read correctly, but the injector constant would be the same?
