Hi team
i recently purshased an ALDL cable and software from tunerpro and it's the first time i connect it to my 92 LT1 Vette. the help file joined with the software explain that i have to send a mode 8 to the ECM before monitoring data to disable comms. But this macro is not stored in the
"1992 - 93 5.7 ( LT1) - Y body $DA2 16159278" adx file (same number as my ecm)
How to i create this macro and use it ?
anyway, i have a lot of DATA Error when monitoring and the values are wrong in the monitor.
Could you help me to solve this problem.
Thank you
Franck
LT1 92 Vette first time using TunerPro
LT192Vette
Re: LT1 92 Vette first time using TunerPro
After little research on the corvetteforum i found the right adx file for a 92 vette. I will check this we
See you
See you
