Plug-in Honda Flasher on Tunerpro RT
Chatchai
Post by Chatchai »
Hi everyone
I'm a beginner please advise.
my question is possible to create plug-ins ADX for VAG-KKL Cable?
It would be great if we can look live parameter and able to record track on the map
in Tunerpro RT software. The ELM327 device seems to be working properly
now I'm using the VAG-KKL cable based on Honda Flasher software comes with an FTDI and K-line chip
Honda flasher & Lonelec VAG KKL cable
links
https://hondaflasher.webnode.fi/
https://www.lonelec.co.uk/Motorbike-OBD ... sher-Cable
Thanks in advance
TunerPro RT | ADX files project creator
ecu tuner
Re: Plug-in Honda Flasher on Tunerpro RT
Post by ecu tuner »
hello sir good job i wantplugin for honda and yamaha flasher sent me on this mail,
topmechanic29@gmail.com
Chatchai
Post by Chatchai »
Looks like someone has ever answered about this
"ELM327 is often used with software for standard OBD2 communication and has built-in support for most common OBD2 protocols. The software communicates with the interface using a special ELM327 protocol. For the stuff in this thread, a "passive" interface is needed. For example Vag-COM 4.09 KKL. The simplest passive interfaces will only convert the voltage level of the K-line to the RS-232 level for a PC. The cables with a USB connection will, in addition, create a virtual RS-232 port, but the result is more or less the same"
In this case I found that ELM327 cannot communicate directly with the K-line and I'm not sure about the protocol of Honda Bike.
is it possible if there is a way to convert this protocol to a other?
anyone have any idea
willmraz
Post by willmraz »
ELM327 cannot communicate directly with the K-line.
mkg
Post by mkg »
Has something changed and someone created a protocol and adx file for realtime communication of Honda motorcycles with tunerpro?
mkg
Post by mkg »
Does it work in other models too?
Shaker666
Post by Shaker666 »
The VAG-KKL interface adapts the K-Line to an RS232 interface, so yes, you should be able to write a new plugin to decode that and an ADX to issue the commands needed to query the appropriate variables.
Chatchai
Post by Chatchai »
