Check for update error
Avinitlarge
Post by Avinitlarge »
When I check for an update, I get the following error, Its the same on all 3 PC's I use
bernhard
Post by bernhard »
me too
checked some week ago, it worked again.
checked this day....descripted error.
maybe a redirektion-problem by the provider of the webspace?
Matrix
Post by Matrix »
go to the web site and check your version number against the latest release. If yours is old, download the latest release manually and install.
http://www.tunerpro.net/downloadApp.htm
Then try check for updates again in the help of the newly installed version and you should get a message "This version is the latest."
This is fixed in the latest version, which you'll have to download from the link Matrix mentioned. Once you're on that version, you should see the version check succeed again.
Sorry for the confusion.
